Activity Forums Maxon Cinema 4D Problem with displacement maps
  • Problem with displacement maps
    Posted by Leonardo Alisievicz on March 15, 2010 at 9:21 pm
    Hi everybody!
    I can´t manage to render a displacement map correctly into cinema 4d.
    This is what I´ve done:
    -Modelled and unwrapped UVs
    -Exported Obj.
    -Sculpted into Zbrush 3.2 in level 7
    -back to level 1
    -Checked Adaptative, SmoothUV and then “Create and export map” (4096 x 4096 px)
    – Exported model to C4d
    -Imported in c4d, loaded displacement map and flipped vertically
    I´ve attached images for every step I´ve done.
    Thanks in advance.
    Leonardo Alisievicz replied 16 years, 6 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    March 16, 2010 at 6:53 pm
    Sounds like you’re doing it the right way. I can’t tell what the problem is without seeing the files.
  • Leonardo Alisievicz
    March 18, 2010 at 6:39 pm
    I fixed it. I just had to uncheck Smooth UVs before exporting my map. Worked fine.
    Thanks anyway!
