Activity › Forums › Adobe Premiere Pro › Problem with Dip to White and Crop Filters
Posted by Greg Burke on March 30, 2014 at 4:00 amClient is very picky, I for the life of me cant figure out why the Crop Bars show up when dip to White trans over the clip? any way to stop this?
I wear many hats.
http://www.gregburkepost.comPaul Neumann replied 12 years, 5 months ago 3 Members · 6 Replies -
Gary Tobyn
March 30, 2014 at 7:58 amIt may be because the transition can only add white to where there is alpha channel for it to act on and colourise to white. And if you cropped the clip the transition is acting on it will also crop the transition effect.
One way around this would be to add a 1 sec (duration is up to you) white matte on the video track above the two clips so that the mid point of the white matte is exactly on the cut point of the two clips.
Either key frame the opacity or use deissolves on the matte that fade up and down leaving the only fully opaque frame to cover the cut.
Greg Burke
March 30, 2014 at 8:12 am -
Greg Burke
March 30, 2014 at 8:22 amActually Found a Solution. Putting a BLACK MATTE underneath the footage stops it from happen, annoying but effective.
I wear many hats.
http://www.gregburkepost.com -
Gary Tobyn
March 30, 2014 at 8:28 amGood to know ,
Still getting to grips with pp and its foibles myself.
But more importantly, why have they got you working on a Sunday?
Greg Burke
March 30, 2014 at 9:10 amHA! Well to be honest Finding Work especially paid work is HARD nowadays, so I work 7 days a week 4-8 hours a day, and am i skype 24/7,
I wear many hats.
