Activity Forums Avid Media Composer problem with deck while digitizing
  • problem with deck while digitizing
    Posted by Rap on September 19, 2006 at 10:12 am
    Hey guys i have 2 questions
    1- i am editing a movie that was shot on DVCPRO50 and i am using a AJ-SD93 Panasonic deck to capture , the problem that i have that while digitizing i get drop frames, anly after few tries of stoping and playing and stoping and playing the deck i get the media in a good way. i changed the FW cable and turned on and off the deck but nothing changed. i’ve been having this problem for a ong time i actually thought tha the drops are on the tapes but after checking that, i noticed that they are not at the same point… any ideas whats wrong?
    one more thing… i have to quite the Avid everytime i turn on the deck and want the Avid to see it… if i don’t do that i get the message that there is no deck
    2- can i use same MOJO on both PC and MAC ?
    thanks in advance
    Jon Zanone replied 20 years ago 2 Members · 4 Replies
  • Jon Zanone
    September 19, 2006 at 11:42 am
    According to the supported devices list, (https://www.avid.com/content/8927/SUPPORTED%20DEVICES%20FOR%20AVID%20EDITOR%20PRODUCTS.pdf) the deck you are using is not supported when using DVCPro50.
    Jon
    “The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
  • Jon Zanone
    September 19, 2006 at 11:44 am
    Oh, I forgot – the Mojo is agnostic. But you’ll need to use your dongle that came off the Mojo system.
    Jon
  • Rap
    September 19, 2006 at 1:46 pm
    Thank you Jon for your reply
    1- this is interesting, then how should i digitize my material ?!!!!
    2- if i use my MOJO that is running now on AXP 4.6 PC , with my AXP 5.5.3 (MAC) dont i need to update the firmware in which case can i still use it wit the 4.6 (and no i cant update my AXP on PC coz i dont have enuogh RAM)
    thank you
  • Jon Zanone
    September 20, 2006 at 12:07 pm
    1. Rent a deck. I don’t know where you are, but I’m sure there’s a rental house close enough to FEDEX something to you.
    2. Buy more RAM? Nobody ever said this is a cheap buisness to run.
    Jon
