Activity Forums Apple Final Cut Pro Legacy problem with cross dissolve
  • problem with cross dissolve
    Posted by Damon Holland on March 17, 2010 at 5:18 pm
    I have two motion clips that I have placed in my fcp timeline that i would like to cross dissolve between. i am having no luck. i have tried zooming in and dragging a cross-dissolve in between the clips. i have tried highlighting the tail and head of the two clips and command T…
    so far i can get a 1 frame cross dissolve that i can not lengthen either by dragging or by numerically changing the duration…
    any suggestions as to why this seemingly simple task is giving me headaches?
    Richard Chenoweth replied 16 years, 6 months ago 4 Members · 4 Replies
  • Shane Ross
    March 17, 2010 at 5:26 pm
    HANDLES!!!
    #1 Transitions “Insufficient Content”
    Shane’s Stock Answer #1: Trying to add a Transition and get the error “Insufficient Content”
    A full 1 second cross fade reaches 15 frames into each clip. So, if you want to change a cut to a cross fade, there has to be at least 15 additional frames of each clip. Say you’re trying to cross fade from one clip into the very first frame of a second clip. FCP cannot ‘create’ 15 more frames of the second clip to do a cross fade. If they’re not there, you’re out of luck.
    What you are running into is that you are marking an out point at the far edges of a clip then adding a cross dissolve, say 30 frames (one second) in duration. Since the dissolve is centered on the cut, it will start 15 frames before the cut, and try to go 15 frames AFTER the cut…which it can’t do. What you need to do is plan how long your dissolve will be and back-time your cut so that it works.
    You need to make sure that your clips have enough media (called ‘handles’) at the beginning of the incoming clip and at the end of the outgoing clip for the transition. For example, if you have a 1 second (30 frame) dissolve, your in and out point need to be at least 15 frames from the edge of the clip.
    Shane
  • Ari Feldman
    March 17, 2010 at 5:30 pm
    You beat me to the punch, Shane. I was just about to post this:
    https://forums.creativecow.net/faq/applefinalcutpro#47
    Ari Feldman
    Editor/Assistant Editor
    Apple Certified Trainer
  • Shane Ross
    March 17, 2010 at 5:36 pm
    Neener neener neener!
    Straight from the horses mouth…
    Shane
  • Richard Chenoweth
    March 17, 2010 at 9:23 pm
    If you use Mac, you can hold down “Control” and click on the seam between the two clips. A cross-dissolve will appear. Then you can double click on the cross-dissolve to get a dialogue box for it.
    Once it’s there, you can go to Effects Menu and toggle it to another type of dissolve if you want.
    To get rid, click it once to highlight then Delete…
    Rich
