Activity Forums VEGAS Pro Problem with Cookie cutter Jerky video
  • Problem with Cookie cutter Jerky video
    Posted by John Bolton on May 12, 2010 at 4:07 pm
    I have seen reports about this problem but not seen any solutions
    Just to refresh If I make a video of a single time line everything it perfect…. If I make a video with two Video time lines the end result after rendering has a type of jerky frame effect. I am not talking about the Preview window… but after it has been rendered.. So If I try and make a video where I have used the Cookie cutter so that it shows part of the second time line, the end rendered result seem to miss every other frame..
    I have tired to Render the original MPEG from my cam to AVI and use both avi videos but it does not seem to make any differnce.. Any Ideas?? Thanks
    John Rofrano replied 16 years, 3 months ago 2 Members · 4 Replies
  • John Rofrano
    May 12, 2010 at 11:24 pm
    I would report this to Sony. They may want to have the veg file. I have seen the same problem with Sony Fill Light. Sometimes it works fine and some times it rapidly turns on and off for no reason. 🙁
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • John Bolton
    May 13, 2010 at 7:35 am
    Hello . Thanks for your reply.. I have also tried my original verion 9a but it does not make any differnce…….I updated to 9d a while ago and it it only recent that I needed to try the cookie cutter to run 2 video timelines at the same time. I can’t beleve I am the only person who has got this problem… There must be some settings that I have not found which overcomes this. I have also tried the MASK to provide a see through area of the first TIME line video but makes not differnce.
  • John Bolton
    June 1, 2010 at 4:11 pm
    Hello all… Well I did eventually find the solution.. The problem was that in the Properties of the video clip I had not DISABLED RESAMPLE.. After doing that and using the 2 * AVI Files the jerky video is now smooth. When the 2 identical timelines where played at the same time all was OK … it was only when I off-set them for the differnce parts of the video I saw this problem
    I have noticed that if I went one frame at a time.. on some frames it would show the same frame for 4 frames.. When I diabled the Resample, it changed with every frame
    Hope this may help someone else
  • John Rofrano
    June 1, 2010 at 11:54 pm
    Excellent detective work! Thanks for posting the solution so that everyone can benefit.
    ~jr
