Activity Forums DVD Authoring Problem with Compressor making basic BluRay
  • Problem with Compressor making basic BluRay
    Posted by Neil Patience on January 17, 2012 at 5:41 pm
    I needed to make a very basic BluRay disc from an HD ProRes QT.
    So in the absence of any “proper” software I tried using the “Create BluRay” template in Compressor.
    I literally left everything default, used the simple black menu that shows the title and a play button.
    Hooked up a Samsung SE 506 to my MacPro dropped in my file and hit the submit button.
    Encoded and H264 video file and an AC3 audio file and then asked me to insert disc.
    One 25 gig BD later and out popped an OK BluRay and it worked just fine.
    The snag is I cannot repeat the process.
    What happens now is that it encodes – asks for disk – then about 35 secs from end of process up pops the “you have inserted a blank disk menu from Apple” I clicked ignore.
    The disk then never finishes but remains with 35 secs to go until I give up and abort.
    Have tried 4 or 5 times on various occasions – rebooted etc etc same result.
    Any thoughts?
    best wishes
    Neil
    http://www.patience.tv
    Neil Patience replied 14 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
