Activity Forums Adobe After Effects Expressions Problem with comments on expressions
  • Problem with comments on expressions
    Posted by Matthieu Foulet on May 19, 2010 at 9:32 am
    Hi everyone,
    I am experiencing a little but quite annoying problem when adding comments on an expression in CS4.
    Whatever the type of comments I use (either // … or /* … */), AE disables my expression, returning the following error:
    Even with a simple line of text like:
    //Test
    Has anyone ever had the same issue ?
    Am I missing something ?
    (AE is up-to-date)
    m
    MacPro 8Core 2.8Ghz (january2008) //
    16GB OWC RAM //
    NVIDIA 8800GT 512Mb //
    OS X.5.8
    Todd Kopriva replied 16 years, 3 months ago 2 Members · 2 Replies
  • Matthieu Foulet
    May 19, 2010 at 9:57 am
    Ok I dealed with two different syntax problems.
    first, if I just tested the comments with a simple line like
    //test
    I was having an error until I just wrote any expression into the parameter.
    What brought me to test it, was another expression for which I had the same problem.
    This one was long and I couldn’t find where my error was.
    Actually, I was commenting it like I am used to in javascript.
    I had comments at the end of some lines, which AE obviously doesn’t understand
    posX=transform.position[0]-sX*width/2; //arete de gauche
    posX1=transform.position[0]+sX*width/2; //arete de droite
    posY=transform.position[1]-sY*height/2; //arete du haut
    posY1=transform.position[1]+sY*height/2; //arete du bas
    However, th expression worked fine in CS3, even with the comments at the end of the lines.
    16GB OWC RAM //
    OS X.5.8
  • Todd Kopriva
    May 22, 2010 at 10:32 pm
    I just tested some comments of the format that you’re talking about, and they work fine for me.
    If you continue to see a problem, please file a bug.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
