Problem with color codes
Posted by Tobin Bell on October 28, 2014 at 4:35 pmhey there,
Is there a way to save or get the color code (eg. #f9d27d) of the text I use in Vegas? I want to use exactly the same color in Photoshop but couldn’t figure out how can I do it.
Stephen Mann replied 11 years, 10 months ago 4 Members · 10 Replies -
Mike Kujbida
October 28, 2014 at 5:36 pm -
Tobin Bell
October 28, 2014 at 5:43 pmThis color picker isn’t from Vegas, right?
I need a color code from Vegas to use it in Photoshop.
To be more simple: I want to use a color in Photoshop that I used in Vegas before. How can I get the code from Vegas? -
Mike Kujbida
October 28, 2014 at 6:06 pmHow did you come up with the values used for your Vegas text?
Use the same RGB values in Photoshop that you did when you created the text in Vegas.
If you’re not sure what those were, click on a text event to open it and then click on the Properties tab to display them. -
Tobin Bell
October 28, 2014 at 6:14 pmI just can’t find that Properties window that contains rgb code. If I rightclick on the event and click on Properties at the bottom it doesn’t show the code. if I open the event the “Sony Titles & Texts” panel show up and there is a color table with so many variations of color formats and next to my text color it says “1,0; 0,93; 0,7; 1,0” but couldn’t figure it out how can I use this “code” in Photoshop. 🙁
Mike Kujbida
October 28, 2014 at 7:21 pmNow I understand. You’re using a newer version of Vegas and, for some insane reason, they decided to switch away from using RGB. Very few of us liked this change and made our opinions known to Sony but the problem remains 🙁
You could multiply 255 by the value you get and use those.
In your case that would be 255 – 237 – 179 but, due to rounding, this may not be identical to your original color.
I would take a screenshot, bring that into Photoshop and use the color picker to determine the color.
Good luck!! -
Tobin Bell
October 28, 2014 at 8:06 pmthanks for the tip, I just did the same meanwhile. Anyway, making a screenshot and paste into PS to get a color means something similar to heading back to stone age to me for some reason. 😛
Also still don’t understand why the developers don’t give us a switching option (hold down a key) to make velocity envelope not to mess up the whole track when trying to move a track dragging from the right edge.
Thank you for your help!
Andrew Lenczycki
October 29, 2014 at 1:42 pmI’ve had the same problem as you describe, and if I remember correctly, I just resized the Vegas and Photoshop (Elements) program windows enough so I could see each at the same time on screen. I then used the Photoshop color picker tool and picked the color from the Vegas window. I’m at work and don’t have Vegas installed on this machine right now, or I would test to verify.
Andrew Lenczycki
Mike Kujbida
October 29, 2014 at 4:23 pmI know what you mean about the stone age 🙁
While thinking about this last night, I remembered a utility that I had completely forgot about but have now rescued from my archives.
It’s a color picker called PointandSee, is free and does a great job.
You can grab it at https://www.pointandsee.co.uk/As far as your complaints about the Velocity envelope, all I can suggest is to drop Sony a line about it and offer suggestions on improving it.
https://www.sonycreativesoftware.com/support/suggestions -
Stephen Mann
October 31, 2014 at 2:33 amI use ColorPix. It’s free and shows you the color code for whatever the mouse is over.
https://www.colorschemer.com/colorpix_info.phpSteve Mann
MannMade Digital Video
http://www.mmdv.com
