Activity › Forums › Adobe Encore DVD › Problem with closed captions in Encore CS6
  • Problem with closed captions in Encore CS6
    Posted by Matt Conrad on December 9, 2012 at 4:25 pm
    This is my first post, so I’ll try to be as specific as possible. I’ve authored a DVD in Encore CS6 using an Mpeg2 and .scc file supplied by a caption company. I’m able to link the .scc file to the timeline in the “properties” tab. When I check the build and author the DVD, I don’t get any errors and the DVD burn is successful. However, I don’t see CC when I check the DVD on my MacBook Pro and TV. Closed Captioning is turned on and I’ve verified this using DVDs that I’ve authored in the past. I’ve done some research and nothing seems to work. The .scc file has the header “Scenarist_SCC V1.0”
    Matt Conrad replied 13 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
