Activity Forums Adobe After Effects Problem with CC Page Turn Effect
  • Problem with CC Page Turn Effect
    Posted by Erik Lindahl on July 15, 2010 at 11:07 am
    I have a problem with the CC Page turn effect in After effects. I am trying to make a movie where a book folds up and you can see the two spreads.
    The cover image that I apply the effect to, is scaled down because I need to scale the book up later. From the CC Page Turn panel, I have set a background to the cover, wich of course is my left spread, and the right spread is an image that is positioned behind the cover.
    When I use the Page turn effect, the result is that as the cover image folds up, it disappear “out of” the layer border. I tried to correct this with the “Grow Bounds” effect… only to see that this causes the background, set in the CC Page Turn effect panel, to be scaled for some reason? If I lower the Grow Bounds pixel amount, the background scales down again, and if I remove Grow Bounds completely, the background seems to be in the correct scale.
    But then if I don’t use Grow Bounds, I can’t see the cover nor the background when the Page turn is complete. Because they are to the left of the original cover image’s layer border.
    Anyone else who has had the same problem, and does anyone have a hint how to solve it?
    Most grateful for help,
    /Erik
    Patrick Rogan replied 15 years, 10 months ago 3 Members · 2 Replies
  • Jens Enqvist
    July 15, 2010 at 10:19 pm
    Pre-compose
    As of CS5 it might not be necessary, otherwise pre-compose to the size that you require for your page turn.
    Cheers,
    -jens
  • Patrick Rogan
    October 27, 2010 at 1:09 pm
    I had a problem with CC Turn, and I know I realize it’s because it’s not a 3D effect. I can’t find those tutorials on 3D Page-Turning, do you have a link or two?
    (A.W.Tozer)
    He that is from above is above all.
    I want to say dear Christians don’t go around apologizing for Him.
    Don’t go around worried because you can’t make His doctrines fit in with what you learned in school.
    All you learned in school was one fallen head instructing another fallen head.
    And you don’t have to apologize for Him.
