Activity › Forums › Avid Media Composer › Problem with capturing audio
  • Problem with capturing audio
    Posted by Noledan on September 7, 2006 at 10:39 pm
    I’m experiencing some problems while capturing. The audio is distorted, sounding almost like a robot voice, when I’m playing back. If I click out, though, and let the audio run with no video playing on the desktop, it sounds fine. I’m running Avid Xpress Pro on a G4 and importing from a Beta deck. Any ideas? Thanks.
    Chuck Reti replied 20 years ago 2 Members · 1 Reply
  • Chuck Reti
    September 8, 2006 at 4:26 am
    From the sketchy description it “sounds like” you might have a feedback loop somewhere along the path. What happens if you disconnect the audio that runs from the Avid’s audio output to the deck’s audio input (assuming your’re wired that way).or turn the Record level controls down all the way?
