Activity Forums Apple Final Cut Pro Legacy Problem with Blu ray encoding.
  • Problem with Blu ray encoding.
    Posted by Kleoniki Alexiou on July 17, 2014 at 9:45 am
    Hello.
    I’m having problem with the quality of my movie. The final bluray dvd or image disc looks very pixelated at the last 15 minutes.
    I have the SONY Nx5 camcorder and i record at HD 1080/50i (FX).
    I use FCP 7.0.3 and i convert the mts files to .mov with the selection ”log and transfer” AVCHD Plug in (Apple pro ress 422 HQ) and i have 1920×1080 with 25 fps mov files.
    After editing, i export my movie (after rendering) with current settings so i have 80 GB movie (one hour).
    So…i want to create a bluray dvd. I’m using toast titanium 11.After encoding i see
    pixels at the last 15 minutes.( i didnt have this problem one month earlierI tested the auto encode and custom encode with this settings…
    Video format MPEG-4 AVC
    Average bit rate 25.5 mbps
    Maximum bitrate 25.5 mbps
    Motion Estimation best (unchecked the half-pel)
    Reenconding always (i tried never and automatic)
    Field dominance automatic.
    Aspect ratio automatic.
    Nothing better….
    I also tasted to share my movie ” bluray dvd” from fcp .I have the same problem.
    I also tasted the Compressor (template for bluray dvd) using these settings…
    H.264 video and dolby digital audio.
    I still have the same problem….
    Is my exported video too big (80 GB for 1 hour) and i have problem with encoding to compress in 25GB for bluray dvd ? Because i had the same problem 3 years ago with 720×576 resolution and you told me to use Compressor (because without compression my video is too big for a 4,7giga dvd).
    Could it be the disc (too slow)?
    i tried to export and encode in different external disks but with no luck.
    The problem isn’t from exported video becuse i played before i try to create the bluray and everything looks ok. Also i tried with another movie and i have the same problem.
    I’m working with iMAC OS X VESION 10.8.5 2,8 GHZ INTEL CORE i7.
    Thanks in advance.
    Kleoniki Alexiou replied 12 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
