Activity › Forums › Boris FX › problem with bcc motion key
  • Peter Mcauley
    November 29, 2011 at 4:43 pm
    There could be several reasons for this, such as:
    • mask not big enough to cover the moving object in every frame
    • replacement range not long enough / too long
    • feathering too big
    • luma comp set too low / too high
    I think your options are either:
    • adjust the aforementioned settings until you achieve the desired result
    or:
    • render the result that you have an re-run the motion key on the rendered result to eliminate the vertical image artifacts.
    I hope this helps.
    Peter.
  • James Stratton
    November 29, 2011 at 5:24 pm
    that was helpfull thanks
    it not quite right yet
    but the figure was very close up and big
    so i guess that might be making it hard work
