Activity Forums Adobe Premiere Pro Problem with AVI Type 1 and 2 files
  • Problem with AVI Type 1 and 2 files
    Posted by Thomas Seifert on April 17, 2005 at 9:25 pm
    Hello,
    I am experiencing a bizarre problem with AVI Type 1 and 2 files. I captured some video with Premiere 6.0 and the clips were automatically saved as AVI Type 2 files, but when the project is exported using the DV500 preset it is saved as an AVI Type 1 file. The problem is that when I then convert this file to the NTSC format the resulting file is not accepted by Premiere; it does not even get a proper icon like the other AVI files I have.
    What’s up with this? Last time I tried this there was no problem, and no change has been made to either Premiere or the PAL/NTSC converter. I tried converting the PAL file to both AVI Type 1 and AVI Type 2 NTSC AVI files but none of them are recognised by Premiere (or anything else on my computer).
    Is this a codec issue? Is it possible to force Premiere to export the project as an AVI Type 2 file, and would it even make a difference?
    Tom
    Oscar G. replied 21 years, 4 months ago 3 Members · 3 Replies
  • Aanarav Sareen
    April 17, 2005 at 9:53 pm
    What are your export settings?
  • Thomas Seifert
    April 18, 2005 at 11:04 am
    Frame size 720 x 576, 25 fps, 16:9 widescreen, export work area only, no audio export, pixel aspect ratio 1.422, codec is Pinnacle DV500.
    Thanks.
  • Oscar G.
    April 18, 2005 at 3:47 pm
    try using virtualdub to convert your videos.Maybe it could help you.
    regards
