Activity Forums Apple Final Cut Pro Legacy problem with audio peaking on playout
  • problem with audio peaking on playout
    Posted by Lee on February 9, 2006 at 4:32 pm
    Hi Guys
    We are having trouble playing out clips from FCP to either a Digi Beta or to an mpeg 2 encoder in another machine
    The audio sounds fine when we are monitoring it within fcp and levels never peak above -12db but when we play it to tape or to the encoder the audio jumps considerably and alomost is distorting, not in fcp but on the levels on the digi and on the canopos GMVRD2200V mpeg 2 rt encoder
    do I need a flying cow DA convertor?
    Any suggestions?
    This is what I’m using
    FCP 5
    Decklink Extreme
    Dual 2ghz G5
    2 gig of ram
    -12db
    Paul
    Lee replied 20 years, 7 months ago 3 Members · 3 Replies
  • Chris Poisson
    February 9, 2006 at 5:03 pm
    Paul,
    I believe your levels to DB should be -20 db.
    Have a wonderful day.
  • Bret Williams
    February 9, 2006 at 7:10 pm
    Everybody sets up tone for whatever headroom they think is acceptable. -20 is extremely conservative. In fact, the lower you set tone, the higher your chance of gettng distortion. For example you set tone at -20 and your peaks are hitting -6 or -10. You hand off the tape to a dub house and they dub it to another tape and they like tone at -14 (standard usually) or even -12. Your -6 peaks are now at +2 or right around 0. Distortion and clpping occurs.
    But, in your internal situation, you have control, so why not simply calibrate the machines? Play tone at whatever level you like out of FCP, and make sure it’s being recorded at the same level or lower to add headroom? For example, if you needed a little headroom, play back a tone signal from FCP at -14, and record it on the digi beta at -20. That may be what Chris was referring to, just needed a little detail. 🙂
  • Lee
    February 10, 2006 at 10:57 am
    thanks for your help
    good information!
