Activity Forums Apple Final Cut Pro Legacy Problem with audio only on channel 2 in raw footage
  • Problem with audio only on channel 2 in raw footage
    Posted by Paul Mosser on March 10, 2016 at 11:02 pm
    Using FCP7, raw footage shot on a Canon XF100. Problem is that footage was shot with audio going ONLY to channel 2. I need to be able to get/hear audio on BOTH channel 1 and channel 2 (dual mono). I know that this must be possible, because I have somehow been able to get some of the clips to play both channels — SOMEtimes!! At other times, the same clip will only play on channel 2!!??? It must be some setting that I sometimes get right, and sometimes don’t, but I cannot figure which setting. I just got done re-transferring footage in using Apple ProRes 422.
    I have tried panning audio in clips, tried turning off one channel or the other in settings — no help.
    Any ideas?
    Paul M.
    Tom Matthies replied 10 years, 5 months ago 3 Members · 3 Replies
  • Paul Mosser
    March 10, 2016 at 11:13 pm
    Any way to “fix” it in FCP7? Even if only in the clips used in the sequence?
    Paul M.
  • Nick Meyers
    March 11, 2016 at 3:15 am
    well if you pan your single clip to the centre, you’ll get audio on track 1 and 2 on export.
    nick
  • Tom Matthies
    March 11, 2016 at 3:45 pm
    Or you can Option/Shift drag your single track down to an adjacent empty track to duplicate it. Pan everything to center and you should be good to go. Even with a single track, if you pan it to center, it will play out of both channels.
    Not my monkeys. Not my circus.
