Activity Forums Apple Final Cut Pro Legacy Problem with applying dissolves, fade in fade outs in normal sky shots
  • Problem with applying dissolves, fade in fade outs in normal sky shots
    Posted by Jas Sekhon on December 12, 2009 at 8:33 am
    The problem i am facing is whenever i am applying a cross dissolve, fade in, or normal opacity adjustments using the pen tool while working on normal shots containing sky the entire clip in timeline shows sort of pixel waves from a lighter area to a darker area …..The clips are in XDCAMHD 422 1080i50 CBR .And the same sequence settings.
    2.26 Quadcore intel Xeon, 6 GB RAM, 2 TB internal Raid 5 using the apple raid card interface, AJA Kona Lhe, Marshall HD monitor,2 view sonic 19″displays, OS 10.5.8, Fcp 7.0.1, and quicktime 7.6.4
    Can anybody please suggest whats going wrong: already tried deleting preferences, took the clips onto a new sequence, tried with changing various values like, shift fields, deinterlace, color correction but to no avail.
    Thanks and regards in advance
    Jas
    Jas Sekhon replied 16 years, 8 months ago 2 Members · 2 Replies
  • David Roth weiss
    December 12, 2009 at 5:29 pm
    Have you rendered the transition?
    Is Full checked in the Render All dropdown menu before rendering?
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Jas Sekhon
    December 13, 2009 at 5:48 am
    Hi David,
    Full is checked on in the Render all menu and also have rendered the transition before viewing it on my broadcast monitor.
    Can this issue be because of interlace thing?
