Activity Forums Adobe After Effects Problem With Animating Camera in CS6
  • Problem With Animating Camera in CS6
    Posted by Evan Robinson on August 13, 2012 at 8:44 pm
    Hi all,
    Ever since cs6, I have a problem animating a camera (virtual camera in AE) with the particle world and or the shatter effect. Lets say I have the particle system set up, or a layer to shatter, ever thing works fine. I can use the orbit tool fine. I as soon as i hit the key frame button, The orbit tools do not work. The camera starts doing weird things, and will work. For instance, I am trying to make a star field, and have the camera slowly zoom in. As I said, i hit animate, and zoomed in, and it does not zoom in. When i hit play, it zooms in a little, then zooms out, and does other weird things. Any one know why this started happening in cs6. I do not have this problem in cs5.5 or cs4.
    Rui Moreira replied 11 years, 3 months ago 3 Members · 3 Replies
  • Tudor “ted” jelescu
    August 13, 2012 at 8:53 pm
    Weird- Maybe Todd can answer that one, but just to be sure file this as a bug with Adobe.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Evan Robinson
    August 13, 2012 at 10:01 pm
    I found the problem, I did not update after effects, now it works
  • Rui Moreira
    June 7, 2015 at 6:49 pm
    Can you share your solution? Im having the same problem with after effects cs6 🙁
