Activity Forums Maxon Cinema 4D problem with animating attributes of texture
  • problem with animating attributes of texture
    Posted by Gerrit Velthuis on November 29, 2011 at 4:26 pm
    I’ve got a nasty problem with animating an attribute of a texture (i.c. the Offset U).
    Here’s what happens:
    I want to make a white area run over an object by animating the Offset U attr. of its texture.
    I’ve done that before and reproduced the same keyframes, values etc. to the new situation.
    But . . . no animation happens.
    This is what I do:
    – In the Timelinemanager I move the slider to frame 100
    – In the attr. manager I set the Offset U value to 16 % and ctrl-click on the black circle next to it; it turns to red.
    – A keyframe appears on key 100 in the Timeline.
    – I move the slider to 200
    – In the attr. manager I set the Offset U value to 36 % and ctrl-click on the yellow circle next to it; it turns to red.
    – A keyframe appears on key 200 in the Timeline + a nice sloping spline to indicate the moving texture.
    – playing the animation ; nothing to be seen.
    The strange thing is:
    – hovering the mouse above the two keyframes in the Timeline indicates the values 16 and 36 %
    – in the attr.manager however, on frame 100, the value of the Offset U is 36 % (the same as on frame 200) and the dot next to it is yellow again.
    – apparently the attribute values in the Timeline don’t correspond with the ones in the Attr. manager.
    I tried to reproduce the same settings as in the earlier project, but there must be something I am overlooking.
    Doing exactly the same in a blank document with a simple cube and the same texture > works perfect.
    Although it won’t help a lot (I guess) I added a screendump.
    Brian Jones replied 14 years, 9 months ago 2 Members · 1 Reply
  • Brian Jones
    November 29, 2011 at 5:58 pm
    Without seeing the scene, it looks like it would depend on the structure of the object and the mapping of the texture. Do you really want U? If it’s a Timeline/AM thing I’d have to see the scene.
