Activity Forums Adobe After Effects Expressions problem with an expression (that works in other composition)
  • problem with an expression (that works in other composition)
    Posted by Constanti Dinu on September 12, 2015 at 8:48 am
    hello guys,
    i have a problem applying an expression, that otherwise works in a different situation in a different comp.
    i have a layer named “Icon options”. in this layer there are some sliders named “1”, another named “2”, “3” and so on
    i have another layer named A,and this layer has a slider named “Opacity number”.
    what i’m trying to achieve is to link the opacity of the layer A to the slider named “1” or “2” or “3” this way:
    – in the layer A i want to assign the number i want in the Opacity number slider, let’s say 2
    – then i want to use the slider named “2” from “Icon options” to modify the opacity for the layer A
    so i’ve tried
    try{
    NAME=Math.floor(effect(“Opacity number”)(“Slider”));
    thisComp.layer(“Icon options”).effect(NAME)(“Slider”);
    } catch (err) {
    x=[0]
    in this point, i’m getting the zero value from the fact that it gets an error. if i remove the catch err, i’m getting this error: Class “Effect” has no proprety or method named “Slider”
    Any ideas?
    Thanks in advance
    Constanti Dinu replied 11 years ago 1 Member · 1 Reply
  • Constanti Dinu
    September 12, 2015 at 8:53 am
    oh, i’m using the same expression ive used in other comp, with variations, that looks like this
    try{
    NUME=thisComp.layer(index).name;
    x = Math.floor(comp(“WORK AREA”).layer(“COLOR US STATES”).effect(NUME)(“Slider”));
    comp(“WORK AREA”).layer(“COLOR SCHEME”).effect(x)(“Color”);
    } catch (err) {
    x=[1,1,1,1]
    here is linked to a color fill
