Activity Forums Adobe After Effects problem with alpha channel in .FLV export
  • problem with alpha channel in .FLV export
    Posted by Bas Mooij on February 19, 2008 at 4:26 pm
    Hi there,
    I want to export a simple AE composition that has a transparant background to the .flv format.
    1. I exported my AE comp to a lossless avi for both RGB and alpha channel. (Tested it, and the alpha channel was preserved succesfully).
    2. Then when I try to convert the avi to a the flv format using on2 Flix Pro, I do not succeed in converting the alpha channel aswell:
    – When I uncheck the Alpha box in video settings, the movie converts succesfully but transparant background is lost.
    – When I do check the Alpha box, the output flash video seems to be 100% transparant (In other words I do not see anything)
    (Even not when I vary between different alpha bitrate percentages)
    Could you please help with this?
    Thx alot in advance!
    Bas Mooij replied 18 years, 6 months ago 2 Members · 2 Replies
