Activity Forums Maxon Cinema 4D Problem with (all) splines in Cinema 4D R16
  • Problem with (all) splines in Cinema 4D R16
    Posted by Jareb Coupe on April 15, 2015 at 4:30 am
    I’m having such a newb issue, and I can’t find the solution anywhere out there or in here.
    I cannot draw any splines. That is, when I choose any spline mode, click to add the first point in any ortho view, whenever I click to add a second point it simply moves the first point to that location. That was linear spline for example. For freehand, when I draw a shape, a new spline object appears in the Objects panel, but nothing appears on screen. Any shape I draw in freehand will trace out as I hold the button down, but then immediately disappears in the viewport when I let go. It may be worth noting that for a brief moment after releasing the mouse button, the mouse cursor turns into a corrupt, hazy blob. Before changing back to the mouse pointer.
    It’s funny, I don’t recall having this issue in the past – but I don’t use the program very often and only recently upgraded to R16 (from R14). In my shame, I’ve tried re-watching some of the original, basic tutorials about spline creation, and the process is simple. Just like drawing a spline in Illustrator.
    Do have some mode or selection that is preventing me from doing this?
    Intel 2700K
    8GB DDR3
    Dual GeForce 560
    Brian Jones replied 11 years, 5 months ago 2 Members · 2 Replies
  • Jareb Coupe
    April 16, 2015 at 2:01 am
    Probably a few laughs reading this.
    The problem was the viewport filters; had splines disabled.
  • Brian Jones
    April 16, 2015 at 2:31 am
    thanks for posting the solution
