Activity › Forums › Apple Final Cut Pro Legacy › Problem with AJA KONA Lhe
  • Problem with AJA KONA Lhe
    Posted by Vladimir Christov on January 8, 2008 at 4:26 pm
    Hello, I have Mac Pro and Final Cut Studio 2 and use Lhe for working with Betacam – Component – 625 25 10 bit uncompress. I have problem with export from Kona using Component out. The movie is not in proper frame rate, like using slow-motion, but on the timeline everything is normal and when use my display for preview movie is ok. Only the problem is when try to play out Pal 10-bit uncompress movie to betacam Sony. My computer is with latest driver from AJA site for Leopard, because i use Leoprad for operating system.
    Please help me if can!
    Regards,
    Vladimir
    Eric replied 18 years, 8 months ago 2 Members · 1 Reply
  • Eric
    January 9, 2008 at 12:38 pm
    sounds like you have an issue with your field order.
    did you capture your source clips in 625 10 bit uncompressed?
    is your timeline also set to 625 10 bit uncompressed??
    what type of display are you watching from? if it is desktop preview, field issues wont show up, they only show up when monitored over a broadcast-monitor (or TV) connected to your LH.
