Activity Forums AJA Video Systems Problem with AJA KONA Lhe
  • Problem with AJA KONA Lhe
    Posted by Vladimir Christov on January 8, 2008 at 10:12 am
    Hello, I have Mac Pro and Final Cut Studio 2 and use Lhe for working with Betacam – Component – 625 25 10 bit uncompress. I have problem with export from Kona using Component out. The movie is not in proper frame rate, like using slow-motion, but on the timeline everything is normal and when use my display for preview movie is ok. Only the problem is when try to play out Pal 10-bit uncompress movie to betacam Sony. My computer is with latest driver 5.0 from AJA site for Leopard, because i use Leoprad for operating system.
    Please help me!
    Regards,
    Vladimir
    Jeremy Garchow replied 18 years, 7 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    January 8, 2008 at 4:06 pm
    Do me a favor. With your sequence selected hit command-zero and tell me the frame rate in your sequence. Then go to the View > Video playback menu and double check that you are set for 625 10 bit uncompressed.
    Jeremy
  • Vladimir Christov
    January 8, 2008 at 4:14 pm
    I do this and the settings for bit rate are same 25. Video playback is AJA 625i 25 10bit uncompress.
    But there have another option AJA 625i 25 DV-10 bit uncompress ?
    If you have another suggestion please….
    All the best!
    Vladimir
  • Jeremy Garchow
    January 8, 2008 at 4:39 pm
    [Vladimir Hristov] “But there have another option AJA 625i 25 DV-10 bit uncompress “
    Only if your footage was dv would you need that, I think. SInce you captured 10bit you shoudl use the 10 bit.
    Someone else was having a similar problem last night on the FCP forum. He said that his quicktime movies were slow on his hard drive as well. What happens if you export the movie as a selfcontained then reimport that back in?
    Jeremy
