Activity Forums Adobe After Effects problem with aftereffects !!
  • problem with aftereffects !!
    Posted by Mark Michael on February 28, 2011 at 5:06 pm
    i got the plugin called partilce illusion for after effects CS4 …it’s job is to allow you to import particle illusion (vfx software) emmiters in after effects…….
    i have everything set up correctly but when i go into add an effect nothing happens. I lay a video down. go to effect>wondertouch>particle illusion, go through the menu and select my effect (and also the emitter doesn’t appear properly in the preview window) then back to the video and nothing shows up…am i doing something wrong?
    BY the way i have the partilce illusion software and it works prfectly !!
    plz help….thx in response
    Jake Grogan replied 15 years, 5 months ago 2 Members · 1 Reply
  • Jake Grogan
    March 12, 2011 at 9:05 am
    there could be something wrong with the disc so reinstall it hope this works 😀
