Activity › Forums › Adobe After Effects › problem with after effects 6.5 pro after upgrading from 6.0 pro
  • problem with after effects 6.5 pro after upgrading from 6.0 pro
    Posted by Joe Brandan on September 6, 2005 at 11:57 pm
    HI i upgraded from 6.0 pro to 6.5 pro and i cant open my old projects which i created in 6.0 pro,it trys to open it and displays a message saying i need to covert the 6.0 pro files to 6.5 pro and then it jams the screen and i cant do anything, also when i try to use time streath and afew other options in 6.5 pro it does the same jams the screen But doesnt display a message. Can anyone PLEASE HELP!!!!!!!!
    Thanks in Advance if anyone can help
    Joe Brandan replied 21 years ago 3 Members · 8 Replies
  • 8 Replies
  • Chris Holland
    September 7, 2005 at 1:02 pm
    If your on windows and using Service Pack 2 that can cause issues. I was getting all kinds of crazy crashes and freezes with SP2. When I went back to SP1 the issues just kind of disappeared.
    Just a suggestion, someone else might have a better idea.
  • Steve Roberts
    September 7, 2005 at 2:16 pm
    Have you tried upgrading AE to 6.5.1? It’s free.
    I don’t know if it will help, though. Sorry.
    Steve
  • Joe Brandan
    September 8, 2005 at 12:14 pm
    Hi i have uninstalled service pack 2 and installed sp1 but the problem is still there i have also installed Adobe after effects 6.5.1 pro and the problem is still there PLEASE any more ideas????
  • Chris Holland
    September 8, 2005 at 1:26 pm
    Did you uninstall Aftereffects and reinstall before you did the 6.5.1 Upgrade. You may have a preferences issue. I can’t quite remember how to change your preferences. I think you go to your local settings and just delete the preference file and then it creates a new preference file when you restart.
    But my suggestion is to uninstall Aftereffects totally then re-install AE 6.5. Then the upgrade. If you haven’t already done that.
    Otherwise I am at a lose. Sorry.
  • Joe Brandan
    September 8, 2005 at 10:43 pm
    hi i have done that but still have the same problem, i just dont know what else i can do!!! i down graded and installed 6.0 pro but it wont even open my old files that it ones use to. any more ideas guys????
  • Joe Brandan
    September 11, 2005 at 1:50 pm
    hi i am quite certain that its a small problem because now i cant even use 6.0 pro when i try and use it. i think its something that is intermingling thats making it crash!! Any suggestions ???
  • Steve Roberts
    September 11, 2005 at 3:45 pm
    Have you tried uninstalling both, then installing them into separate directories, named for the specific version?
    I’ve never had problems with multiple versions in separate diectories.
    Steve
  • Joe Brandan
    September 14, 2005 at 5:53 pm
    Hi i finally got it working, But i did it the hard way, I formatted the Hard drive then installed it and it started working LOL
