Activity Forums Adobe After Effects Expressions Problem with a simple expression
  • Problem with a simple expression
    Posted by Philippe Lessard on March 24, 2016 at 4:24 pm
    I cant figure out what wrong with this expression:
    opacity=thisComp.layer(“soundhomme”).effect(“Sound Keys”)(“Output 1”);
    if (opacity <; 50){ (100); }else{ (0) ; } Like you see I use the soundkey plugin output that return values between 0-100 from audio analyse. I want the value to be 0 or 100, so rounded values.I pickwip the output value of soundkey from the opacity of the layer I want to animate, than add the "opacity=" at the beginning of the expression, and the " if (opacity < 50){(100);}else{ (0) ; } " at the end. Also it return no error! Thanks opacity=thisComp.layer("soundhomme").effect("Sound Keys")("Output 1");
    if (opacity &lt; 50){
    (100);
    }else{ (0) ; }
    Philippe Lessard replied 10 years, 6 months ago 2 Members · 2 Replies
  • Dan Ebberts
    March 24, 2016 at 5:46 pm
    You shouldn’t use opacity as a variable name. I’d do it like this:
    sk=thisComp.layer(“soundhomme”).effect(“Sound Keys”)(“Output 1”);
    if (sk < 50) 100 else 0
    Dan
  • Philippe Lessard
    March 24, 2016 at 8:42 pm
    Hi Dan,
    Yep that was good idea…
