Activity › Forums › Adobe After Effects › problem with 3d invigorator?
  • problem with 3d invigorator?
    Posted by Ramil on July 16, 2005 at 9:47 am
    Im using a demo ver 4.0 pro and in the manual it says that I can select sets in the scene preview window by using the shift key. But I cannot do this. I’ve assigned two objects inside the set up window as set 1 and 2 respectively but when im already in the scene preview window it seems that i can only select one set and even though I’m holding the shift key i cannot select the other object?
    is there a work around in this problem?
    thanks.
    Ramil replied 21 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
