Activity › Forums › Adobe After Effects › problem with 24bit png (not transparent)
Posted by Eric Viebe on February 23, 2013 at 8:34 amhello,
when i import my image files in png to after effects they arent transparent.the transperency grid is checked.i saved the file with 24 bits in photoshop as “save for web”,but it won’t work. can anyone say what i am doing wrong?
EDIT: the transperency only works with one png image from google the other two also form the web like i said.even after resaving as 24bit png in ps.Steve Hardie replied 9 years, 5 months ago 4 Members · 7 Replies -
Tero Ahlfors
February 23, 2013 at 9:08 amDoes your photoshop project really have transparency in the image? Because I tried to make a 24 bit PNG with transparency and it worked.
Eric Viebe
February 23, 2013 at 9:27 amhello, i’ve just downloaded the imgages from the internet and resaved them in ps.in the options at save for web the transpereny was checked.
Vishesh Arora
February 23, 2013 at 9:42 ami’ve just downloaded the imgages from the internet and resaved them in ps.in the options at save for web the transpereny was checked.
I seems that there is no transparency in the Original Image File that you have downloaded from web.
As Tero said, there should be transparency in the Photoshop Document. Just select the White or Black BG using Magic Wand Tool and delete that in such a way that you have the main subject only. You will see white and black small squares as BG in Photoshop. Now save the file as 24 bit PNG.
Check this link for help:
https://www.mediacollege.com/adobe/photoshop/transparent/background.html
Vishesh Arora
3D and Motion Graphics Artist
Films RajendraBlog:
https://digieffects.wordpress.com2011 3D Demo Reel:
https://www.youtube.com/watch?v=lHPgIJU_BR8 -
Eric Viebe
February 23, 2013 at 10:47 amthank you very much for this link. after edit there is transperency there.
Tero Ahlfors
February 23, 2013 at 11:01 amIf you download some random picture off the internet it won’t magically create transparency even if you export it with it 😉
Vishesh Arora
February 23, 2013 at 2:24 pmGlad I could help.
Vishesh Arora
Films RajendraBlog:
Steve Hardie
April 14, 2017 at 5:20 amMight be worth mentioning that I had the same issue and was scratching my head. I did all of the above but realized thet the image was greayscale and not RGB, so even though it showed the chequered transparency etc it still was coming up as a solid in AE. Maybe obvious but thought it could help incase others come across this.
