Activity › Forums › Boris FX › problem whit boris fx bcc 7 and ppro cs5.5
  • problem whit boris fx bcc 7 and ppro cs5.5
    Posted by Shai Malul on December 8, 2011 at 8:23 am
    i have trying to put on some effects on video and it’s not working,what i mean is that after i put the effect on and i try to play the specific capture (whit the effcet) it is not playing smooth and start to flickering and the end freeze completely. some times hes bring down the all ppro.
    its happen just in the bbc collection.
    machine: i7 64bit win 7 8gb gtx 470
    some help plz?
    Shai Malul replied 14 years, 10 months ago 2 Members · 3 Replies
  • Peter Mcauley
    December 8, 2011 at 4:29 pm
    Hi Shai,
    Are you rendering and then trying to playback the clip or are you trying to playback the filtered result before you render? It may be that the effect is not real-time and therefore requires a render before it will be able to play without stuttering.
    I hope this helps.
    Cheers,
    Peter.
  • Shai Malul
    December 8, 2011 at 6:12 pm
    no i try to play them whitout rendering them, but i dont think that is connected.
    if i need to render every filter to just see samll preview it well be ednlles.. i have must to change every filter settings when i use it’ so every time i cange the settings i need to render? it is not make sense.
    i think that something else dude.. no?
  • Shai Malul
    December 8, 2011 at 6:49 pm
    to a 5 sec cuptare he doing a over 3 min rendirng
