Activity › Forums › Adobe After Effects › Problem while Keying black silhouette video in Adobe After Effects
  • Matt Collett
    December 15, 2015 at 2:08 am
    Im guessing your problem is that it isnt a pure silouette, ie the background behind the girl isnt white. you need to add effects to the girl and play with the levels or curves until the background is completely white. Then you can use that image as the key, it will be a luma key as you are using the white levels to key out the landscape image.
    So your final layers will be: bottom – 1st image of girl. middle layer landscape with ‘luma inverted matte applied’. and top layer will be the girl with effects applied to seperate the girl and her background as best you can. precomp this top layer and do what ever you can to seperate her and the background. curves probably wont do it you can also use ‘change color’ ‘hue saturation’ and probably some rotoscope with masking. Good luck!
  • John Cuevas
    December 17, 2015 at 2:01 pm
    Generally for a sihouette, it’s easier to shoot it on a green screen, key it, and then use that key as a matte layer over a solid(black in your case). If your camera was locked down, you could give the difference key a shot.
    https://www.youtube.com/watch?v=pzvT9cwAYkE
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
