Activity Forums Apple Final Cut Pro Legacy Problem while exporting
  • Problem while exporting
    Posted by Himanshu Bhatnagar on September 2, 2011 at 12:36 pm
    Hello,
    I’m facing a weird a problem. I’m trying to export a 15 sec clip from FCP project but the output I’m getting is more than 15 sec. It adds some some slug on its own.
    I have also tried exporting with mark-in and outs but still the same result.
    Is it because my footage is in NTSC and I’m trying to export in PAL?
    Thanks in advance.
    Himanshu
    Steve Eisen replied 15 years ago 3 Members · 2 Replies
  • Jerry Hofmann
    September 2, 2011 at 2:33 pm
    Not sure what’s going on, but try exporting the sequence as a self contained movie using current settings, then open that file in Compressor for the transfer to PAL.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Steve Eisen
    [Himanshu Bhatnagar] “Is it because my footage is in NTSC and I’m trying to export in PAL”
    It certainly is. You simply can not export an NTSC to PAL. Different frame rates. You need to convert your NTSC to PAL.
    Use Compressor for free or Use Nattress Convertor for $99.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
