Activity Forums DaVinci Resolve Problem when using Deliver module
  • Problem when using Deliver module
    Posted by Nishi Sharma on February 4, 2021 at 11:41 am
    I am encountering a strange problem in stabilizing the handheld footage. The exported clip through Deliver module looks fine, the clip stabilizes fine but right in the last few frames, the clip tilts clockwise making the clip unusable. It has happened on every clip I have tries to stabilize.
    The clip looks fine in the Timeline but this strange tilt happens only on clip export through Deliver module.
    Here is an example: https://vimeo.com/507945171
    However, if I export it by right-clicking on the clip in the Timeline or Use Quick Export then the exported clip is absolutely fine.
    I am using Resolve 17.08 build 23 on Mac running on Mac OS bigSUR, 16GB RAM.
    Has anyone come across this issue?
    Nishi Sharma replied 5 years, 7 months ago 2 Members · 2 Replies
  • David Baud
    February 6, 2021 at 9:20 pm
    Are you exporting using Individual Clips in the Delivery page? Did you add some frames handle to your clip delivery?
    This settings will export your clip you work on (stabilized) and add frames before and after the IN & OUT without being stabilized.
  • Nishi Sharma
    February 7, 2021 at 6:05 pm
    Hi David,
    I’m exporting individual clips, no handles.
    Thanks.
