Activity Forums Adobe After Effects Problem when trying to render Composition.
  • Problem when trying to render Composition.
    Posted by Jason Meno on June 9, 2008 at 12:53 am
    I have After Effects CS3, and have finished a segment of a composition that is only about 10 seconds long. I have tried rendering it, but when it is completed (which eerily only takes 1 second), the final product is just a single frame from the end of my composition. I don’t know what to do, and I have tried rendering it in different codecs and different file types.
    Kostas Aspiotis replied 18 years, 3 months ago 3 Members · 3 Replies
  • Bill Kelly
    June 9, 2008 at 4:30 am
    It sounds like you don’t have your work area set to the entire length of the segment that you want to render. Go to the first frame you want to render and hit “B” on the keyboard. The little blue thing above the timeline should snap over to that. Now go to the last frame you want to render and hit “N” on the keyboard. The other little blue thing above the timeline should snap over to that. Now you’ve defined your work area. If you render now you should get everything between the two blue markers.
  • Jason Meno
    June 9, 2008 at 11:26 am
    Thank you very much! This solved my problem immediately! I am very happy now!
  • Kostas Aspiotis
    June 20, 2008 at 8:46 am
    Hello to every one there!
    I’m a new user with AE and i have only one question at the moment!
    How can i export my progect to my computer?
    I can do a few things in AE but i can’t save them as video.
    Please help.
    Thanks in advance.
    Kostas Aspiotis
