Activity Forums Apple Final Cut Pro Legacy Problem when importing great quality screen captures in quicktime and when opening in FCP the quality is poor
  • Problem when importing great quality screen captures in quicktime and when opening in FCP the quality is poor
    Posted by Jackknife on March 20, 2007 at 4:07 pm
    Hello,
    I have a problems I am hoping someone here can help with.
    I am using Final Cut Pro 5 with all updates current.
    I made a lot of screen captures (text based mostly with some images) to make a podcast with (screen captures were made at 800×600 resolution) When I look at the captures with Quicktime Pro, they are in pristine quality and will blow up to full screen with out fuzziness.
    However, when I brought them into FCP to add the sound and edit the lengths of the clips and make the presentation I found that when I viewed the Quicktime clips I imported into FCP the quality was very poor (to the point of not being able to read the letters which I could before in Quicktime Pro.
    I am at a loss. I am doing this Podcast for a School and want it to be the best it can be.
    Any assistance I can get with this problem would be greatly appreciated,
    Thank you,
    Robert
    EGBOK. if you remember to back up youe data.
    Lawrence Eaton replied 15 years, 3 months ago 10 Members · 16 Replies
  • 16 Replies
  • Kevin Monahan
    March 20, 2007 at 4:50 pm
    Change Canvas Size to 100%. How does it look now?
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Jackknife
    March 20, 2007 at 5:01 pm
    Still poor image when canvas at 100%.
    I am not sure why.
    Also, when I exported to quicktime is is worse (verymuch unreadable) No compression added.
    I did some trials this morning also, getting some more screen captures at various resolutins from 800×600, 1024×768, and 1680×1050 (all non-streched) on my macbook pro and I kept getting the same problem.
    Very fustrating.
    Thanks again.
  • Mark Maness
    March 20, 2007 at 6:00 pm
    What are you saving these files as?
    PICT, PSD, Quicktime (what codec?)…
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Andrew Kimery
    March 20, 2007 at 6:59 pm
    What codec are you editing in in FCP? If it’s DV then your resolution is 720×480 (regardless of what res your source material is at) and DV compression isn’t very nice to text.
    -A
  • Andrew Kimery
    -A
  • Jackknife
    March 20, 2007 at 9:34 pm
    saving as Quicktime then bringing into FCP as quicktime. (no codec other than just Quicktime
  • Jorge Molina
    March 20, 2007 at 9:36 pm
    Quicktime is not a codec but a container. You can have DV/DVCPRO50/Animation/Uncompressed/whatever-quality coded Quictimes. I would recommend using Uncompressed 8-10 bit for most mundane works.
  • Rafael Amador
    March 21, 2007 at 2:37 am
    And have you de-interlaced the footage before make the stills?
    Rafael
  • Mark Maness
    March 21, 2007 at 1:14 pm
    Let me ask you this, Jackknife…
    Why are you saving them as Quicktime? If these are still frames, save them as still frames. You can use the deinterlace filter that FCP has and then grab your stills as PSD or PICT files. Saving them as Quicktime is only another step that is causing you grief.
    Wayne Carey
    Schazam Productions
  • Jackknife
    March 22, 2007 at 7:34 pm
    These are not stills. It is a quicktime movie of moving screen capture of the mouse moving pointing to this and that during a tutorial.
    Not a still though
    Robert
