Activity Forums Storage & Archiving Problem when I login the iscsi hard disk
  • Problem when I login the iscsi hard disk
    Posted by Irrani Dam on November 25, 2009 at 9:18 pm
    We use CentOS 5.3. When I login the iSCSI hard disk, it show the below
    information. I am confusing about this.
    Anyone can give me a help~~~Thanks~~~
    iSCSI Target: Microsoft iSCSI Software Target
    iSCSI Initiator: iscsi-initiator-utils-6.2.0.871-0.10.el5
    [root@localhost /]# iscsiadm -m node -p 10.6.64.140 -l
    Logging in to [iface: default, target: iqn.1991-05.com.microsoft:wss-
    iscsi-test1-target, portal: 10.6.64.140,3260]
    Login to [iface: default, target: iqn.1991-05.com.microsoft:wss-iscsi-
    test1-target, portal: 10.6.64.140,3260]: successful
    Vendor: MSFT Model: Virtual HD Rev: 3.2
    Type: Direct-Access ANSI SCSI revision: 05
    SCSI device sda: 41943040 512-byte hdwr sectors (21475 MB)
    sda: Write Protect is off
    sda: got wrong page
    sda: assuming drive cache: write through
    sda: got wrong page
    sd 6:0:0:0: Attached scsi disk sda
    sd 6:0:0:0: Attached scsi generic sg0 type 0
    Regards,
    Irrani
    Irrani Dam replied 16 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
