Activity › Forums › Adobe Premiere Pro › Problem when exporting to HDV audio and video cuts
  • Problem when exporting to HDV audio and video cuts
    Posted by Alfonso Gomez on October 7, 2009 at 9:00 pm
    Hello friends, I have a problem when trying to export to tape HDV.
    Transcoding and recording to HDV performed perfectly.
    When I check the result on the tape are cuts or breaks in the video and audio tenths.
    I have made many new tape copies and the problem continues.
    Cuts are not always in the same place, Are random.
    In 60 minutes can be 3 or 4 cuts.
    I checked the wires and have even used multiple recorders and is always the same.
    Project data are:
    HDV 1080i (50) 1440×1080, 25 fps, 48000hz, 5.1 PAL
    Video file format blu-ray m2v.
    Pc Windows xp, Intel core duo (2), 6600, 2,4 GHZ, 4gb RAM.
    Use CS3 and CS4 and the problem continues.
    I have worked previously with this equipment on other projects and did not occur.
    I think the problem may lie in the type of files that use.
    As work is very large (1351 videos) have split the project into three parts and Las I exported blu-ray format m2v.
    After I joined Las three parts and exported to HDV.
    Cuts and loss of signal on the tape match level changes.
    I have applied the filter limitation of video Premiere and the problems continue.
    I do not know what else to try.
    Alfonso.
    Alfonso Gomez replied 16 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
