Activity Forums Sony Cameras Problem Viewing XDCAM proxies
  • Problem Viewing XDCAM proxies
    Posted by Nate Gross on October 14, 2010 at 5:55 pm
    I have been sent some XDCAM proxies that came in as .mov files. I need to know how to view or convert them to a viewable quicktime file, or something similar. When I play them in quicktime I get perfect audio, but no picture. I downloaded XDCAM transfer, but it said I was missing codecs and wouldn’t even let me select the files. I don’t have Final Cut so that may be part of the problem. Is there a way I can view or convert these so that I can load them into Avid.
    Ian Cook replied 15 years, 10 months ago 2 Members · 3 Replies
  • Ian Cook
    October 14, 2010 at 6:37 pm
    Hi Nate,
    Without FCP you won’t be able to view the files in QuickTime. I would try downloading the trial version of Calibrated Software’s MXF component; I believe that has support for the MPEG4 Proxy Codec.
    Ian
  • Nate Gross
    October 14, 2010 at 10:37 pm
    Thanks Ian
    I’ll give that a try. I do have an older version of Final Cut Express, but as I understand it, it needs to be Final Cut Pro. Is that correct?
  • Ian Cook
    October 14, 2010 at 10:43 pm
    Hi Nate,
    Yes, my guess is Express will not work with the proxies either as Apple only puts the Pro codecs in Final Cut Pro..
    Ian
