Activity › Forums › Apple Final Cut Pro Legacy › Problem using Chroma Keyer in FCP 6
  • Problem using Chroma Keyer in FCP 6
    Posted by Rosie Nakamura on June 11, 2009 at 8:59 pm
    For some reason the chroma keyer in FCP is not working – only on footage shot from two different shoots. Instead of eliminating the green, it’s creating a thin keyed line around the subject’s head – that’s it.
    This is green screen footage shot using the HVX200 in 720p30. The strange thing is that it continues to work fine with other footage shot using the same camera in the same record mode, but just not these two shoots. I have tried it on different computer systems in our office and it’s the same thing across the board. It doesn’t work on any of them. I’ve tried putting the source footage on different drives and logging & transferring from different systems to create quicktimes and that had no effect. Does anyone know why this is happening or any potential solutions to the problem?
    For the record, the green screen is shot beautifully and it keys perfectly in After Effects. I am using FCP 6.0.5 on Mac Pro Quad Core.
    Rosie Nakamura replied 17 years, 3 months ago 2 Members · 2 Replies
  • John Fishback
    June 11, 2009 at 9:45 pm
    I’ve never been happy with my results using the keyer in FCP. I usually use Keylight in AE. Since you have it, why not key there? Motion has a much better keyer (Primatte) than FCP. If someone can’t help with the FCP key, try Motion. At least you can round-trip from FCP.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Rosie Nakamura
    June 15, 2009 at 7:16 pm
    I think I’ve figured out the problem, but it’s really odd. The saturation of the green color seems to be too intense for the chroma keyer in FCP to handle. If I desaturate the color of the entire frame it will then key with no problem. I have no idea why this works, but I’m happy there is a workaround. It keys just fine in Motion & After Effects, but for this job, it’s way easier to do everything in FCP.
