Activity Forums Apple Final Cut Pro Legacy Problem using Boris into FCP
  • Problem using Boris into FCP
    Posted by Jean-francois Joanisse on May 29, 2008 at 4:55 pm
    For some reason I am loosing my alpha properties when I export an animation from Boris Red into FCP. This occured only after I’ve unlocked my Boris software after the trial version expired. I’ve succesfully exported my previious animation. And I do make sure to check the Alpha option to “straight”
    When I check my clip property in FCP in sais Alpha : nono/ignored.
    Help will be appriciated.
    Technical info : Power Mac 2×3.2gh Quad Core Intel
    memory : 2Go 800MHz DDR2 FB-DIMM
    It’all an illusion
    Jean-francois Joanisse replied 18 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
