Activity Forums VEGAS Pro Problem tying to reverse clips in Sony Vegas Pro 11
  • Problem tying to reverse clips in Sony Vegas Pro 11
    Posted by Robert James on September 15, 2014 at 5:04 pm
    When I try reverse clips in Sony Vegas by right clicking on the clip and selecting reverse or
    using the velocity envelope I either get choppy and or freezing of the clip or whole video I’m editing (right click method) Or, after reversing a part of the video plays that was not in the clip I was trying to reverse. The reversed clips cause the same problem while editing and after rendering.
    I usually don’t have this problem. It has only happened with three projects. There must be something about the video clips. What could cause this and is there a way to fix it?
    Graham Bernard replied 11 years, 11 months ago 3 Members · 3 Replies
  • Graham Bernard
    September 15, 2014 at 5:07 pm
    Render to a Digital Intermediate.
    Grazie
  • Stephen Mann
    September 16, 2014 at 4:40 am
    Grazie is correct.
    The problem with reversing a GOP format, as most of our work is, is that compression is forward-looking. You start with an I-frame followed by some P-frames which only need to hold the differences from the most recent I-frame. When you play it backwards, the program has to look for the next prior I-frame, build complete frames in memory that haven’t yet been played, then jump back another I-frame and start over. Quite a lot of computing there and most PC’s can’t keep up with it, so reversed video preview can be choppy.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Graham Bernard
    September 16, 2014 at 10:00 am
    [Stephen Mann] “Grazie is correct.”
    But now I know WHY I was correct! Steve, thanks for the fulsome explanation – I really really didn’t have a clue. What I DO know is that if Media is misbehaving, bash it with a DI.
    Grazie
