Activity › Forums › Apple Final Cut Pro Legacy › Problem: Transferring HDV Quicktime clips from FCP to PC machines
Posted by Mark Wunsch on January 19, 2006 at 10:18 amHi,I have to provide HDV and DV footage/clips to customers that work with PC
Alieninnovation replied 20 years, 8 months ago 4 Members · 5 Replies -
Shane Ross
January 19, 2006 at 10:28 amThe DV files shouldn’t be a problem. But HDV…now that will be. You need the latest version of quicktime and FCP for you to view them. On a PC, they can’t vew them…due to the GOP structure and way FCP captures the footage. Avid Express Pro HD now can capture HDV natively, but in a different format (wrapper…codec, whathaveyou). You aren’t going to be able to exchange the HDV files this way.
As for teh 2 GB file limit…that is the reason many PC formats limit file sizes to 2GB…because PCs have trouble reading them.
And people wonder why we like Macs so much. Sheesh.
Shane Ross
Alokut Productions
http://www.lfhd.net -
Alieninnovation
January 19, 2006 at 2:52 pmI was just told had nothing to do with the GOP structure since they are standard.
If not, could you explain me why and how it does not work do to the GOP structure?iMac G5 17″
Final Cut Studio -
Steve Teak
January 19, 2006 at 6:39 pmI understood the GOP structure was determined by the camera recording information to tape initially and not the capture of it.
Did you end up with your capture as a mpeg2?
HDV footage I captured (on a pc) was viewable with Windows media player on pc and quicktime 6 on mac, with mpeg2 component. But to edit it was a pain had to export to a mov. first. Can be done with FFmeg streamclip.
Also I found that the mpeg2 clips were stuttery in some slightly older pcs using WMP, just a disk streaming and processing thing. So a standard office pc would have trouble playing them.Steve
Alieninnovation
January 19, 2006 at 9:13 pmSo it has nothing to do with the GOP?
iMac G5 17″
Final Cut Studio
