Activity › Forums › Apple Final Cut Pro Legacy › problem to export the right framing
  • problem to export the right framing
    Posted by Marianne Souliez on November 30, 2010 at 2:53 pm
    Hello,
    I have to make a quicktime of a messed up video that I had to resize (changing cale and aspect ratio) in order for it to fit into a 16:9.
    Everything appears correct in the Canvas, but when I export it, in quicktime or converting it, I get a different frame (the bottom is cropped ).
    If anyone can spot what the problem is, that would be grand.
    (I have tried to upload a print screen but I get a dozen pages to fill up and it does not even happen in the end)
    thanks a lot!
    Marianne
    Rafael Amador replied 15 years, 9 months ago 2 Members · 1 Reply
  • Rafael Amador
    November 30, 2010 at 4:37 pm
    Hi Mariane,
    A bit of additional info (original format/size, intended format/size, sequence setting), would make easier to try to help you.
    With what you say here, is all guess.
    rafael
    http://www.nagavideo.com
