Activity Forums Apple Final Cut Pro Legacy Problem Setting Up Scratch Disk with FCP 7
  • Problem Setting Up Scratch Disk with FCP 7
    Posted by Ron Schotland on January 20, 2013 at 10:40 pm
    Hello,
    I just created a new external scratch disk (rather than the Mac hard disk) with more storage capacity than another external scratch disk I had been using until now. The problem I am experiencing is in transferring the FCP video files to the new scratch disk.
    This is the procedure I have been using: 1. Open a new Project (A) on the new scratch disk, select the project name and ‘Save As”. 2. Click on System Settings and Click Set (as per standard procedure). 3. Cut and paste the files from the old scratch disk over to the new one (placing the files in the same places as they were on the old scratch disk. 4. Click Save Project.
    I repeated this procedure by transferring another Project (B) to the new scratch disk, (repeating steps 1 through 4), assigning System Settings for Project B. Now here is the where I encounter the problem. When I return to Project A and review its System Settings, they now are the same as the latest ones I had just set for Project B.
    Can you please tell me what I am doing incorrectly? Could it be that the procedure I am following in transferring a project from one scratch disk to another is incorrect?
    Any suggestions for circumventing this problem would be most appreciated.
    ronschotland@yahoo.com
    Ron Schotland replied 13 years, 7 months ago 2 Members · 2 Replies
  • Rafael Amador
    January 21, 2013 at 3:15 am
    I think you don’t have much clear the concept of Scratch Disk.
    The Scratch Disk is where FC writes certain stuff (including captures and Log&transfer) files, but is not necessarily your “media HD”.
    [Ron Schotland] ” When I return to Project A and review its System Settings, they now are the same as the latest ones I had just set for Project B. “
    The Scratch Disk is not associated with any particular projects. Is the one that the application use.
    When you change the scratch disk you set the disc which FC will use from that moment and whatever project you open, old or new, will use that Scratch disk till you set a new one.
    If you want to move media from one disk to another, just drag and drop the folders where your media resides trying to keep the same folders structure.
    Once you have transferred the media, if you want a project to use the media on the new HD, switch off the old HD, open the project and use the emerging window to reconnect the media files. Once FC has retrieved the files, save the project. so FC won’t look again for these files on the old HD.
    rafael
    http://www.nagavideo.com
  • Ron Schotland
    January 22, 2013 at 6:09 am
    Rafael,
    Thanks for setting me straight on the scratch disk concept. This is
    something I should have learned long before this. Now everything is starting to make more sense.
    Appreciate you help.
    Ron
