Activity Forums Apple Final Cut Pro Legacy problem sending a clip from FCP timeline to Motion and back
  • problem sending a clip from FCP timeline to Motion and back
    Posted by Alvaro Lanciai on February 4, 2010 at 9:53 pm
    Hi there,
    I’m getting crazy…I send a clip from FCP TO MOTION 4.01 and i use the paint stroke tool to draw on my clip using “LIQUID/INK DILATE 01” as shape style.
    with motion there are no problems…but when I save the project and i come back to FCP the clip doesn’t work correctly….i cannot see correctly the paint stroke I made in motion, but i see the clip without drawings…
    Changing the shape style, in FCP I see also a series of black rectangles following the shape i draw…
    It happens if I set the SHAPE/STYLE/OUTLINE/BRUSH TYPE to “Image”…
    But if I set it to “Airbrush” or “Solid” it will correctly displayed in FCP….
    I tried with blend mode NORMAL and ADD….
    I tried setting every kind of Background (solid,transparent, environment…) in the project properties…
    I already trashed preferences etc etc….
    PLS HELP ME !
    Alvaro
    MAC INTEL dual quadcore 3ghz
    8gb ram
    macos 10.5.8 and macos 10.6
    fcp 7
    Alvaro Lanciai replied 16 years, 7 months ago 2 Members · 4 Replies
  • Jerry Hofmann
    February 6, 2010 at 1:49 pm
    Try exporting a QuickTime Movie from Motion, then use that file in FCP.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Alvaro Lanciai
    February 6, 2010 at 10:36 pm
    Sure….
    If I render the project or export the QuickTime it works fine…. But I\’ve to prepare a lesson about sending files from FCP to motion and back…it is for an exam at Apple (T3) and I\’ve to demonstrate it without render or export…
    8gb ram
    fcp 7
  • Jerry Hofmann
    February 7, 2010 at 1:10 pm
    Might try trashing the plist for Motion… it’s in the User/Library/preferences folder.
    Jerry
  • Alvaro Lanciai
    February 7, 2010 at 2:23 pm
    hi there…
    I tried to trash all motion and fcp prefs…but nothing changed…
    today I have reinstalled the suite…..everithing works fine now….thank tou
    alvaro
    8gb ram
    fcp 7
