Activity › Forums › VEGAS Pro › problem rendering with Magic bullet looks and Vegas Pro 9
  • problem rendering with Magic bullet looks and Vegas Pro 9
    Posted by Kadshah Nagibe on November 9, 2009 at 7:24 am
    Hi all,
    I’m having problem rendering in Vegas Pro 9 when using magic bullet looks 1.2. I didn’t have this problem before it started about the same time
    I installed 9.0c. Anyway I contact Red giant they told me to try this:
    1. If you are using another GPU based program, please disable when using the product. This includes, but is not limited to applications from your
    video card maker. (i.e. ObjectDock application and Nvidia nView Desktop manager, ect..)
    2. Please be sure your video card drives are up to date. If so, then please try reverting back 3-4 driver versions to see if this solves your issue.
    3. Be sure that you are not exceeding the resolution limit of your video card with your project.
    4. There may also be a program running in the background that is conflicting with the plug-in. Please perform a clean boot of your system. For instructions
    from Microsoft, please refer to: https://support.microsoft.com/kb/331796
    5.Then open a brand new (non-existing) project in Vegas and apply Looks to 720×480 footage and render.
    video card)
    Tried it all didn’t work. I reinstalled WinXP pro SP2 with only the important windows update before adding adding the video card and latest driver.
    (Radeon HD 4870 1GB 256-bit GDDRS PCI express 2.0 x16) No firewall or virus scan software. I tride different settings within the Catalyst control
    center and ATI overdrive settings but nothing worked. If I don’t use Magic bullet looks it renders fine if I try a look any look within magic bullet
    looks it will start rendering but when it gets to around 17% it hangs. I’ve tried different projects. When it doesn’t hang I get “the system is low
    on memory” error message. I have tried a different graphic card and it worked like a charm so my guess is it has something to do with the graphic card.
    It got the Radeon 4870 back in June and it’s been working fine under Vegas Pro 9.0a/b. I have tried older drivers but that didn’t help. I’ve been to
    the Vegas 9 Pro, Radeon and MBL’s troubleshooting section and have tried everything suggested but still doesn’t work. I’m wondering if maybe the card
    might be defective. I’ve downloaded and ran the video card stability check and the ATItool utility. Both test came out fine. I’ve also disable startups
    and programs running in the background. Any suggestions?
    Osver Torres replied 16 years, 8 months ago 3 Members · 3 Replies
  • Ian Newland
    November 9, 2009 at 8:40 pm
    I’m having the exact same problem, was ok with 8c. I’ve given up using MB till i find a solution.
    Cheers Ian
  • Kadshah Nagibe
    November 14, 2009 at 5:48 am
    Problem solved it was a graphic card driver issue. I tried 3 legacy drivers and the oldest one worked.
  • Osver Torres
    January 22, 2010 at 5:50 pm
    Hi, I have almost the same problem, Use Magic Bullet in SonyVegas Pro 8. I have a Sony vaio with processor 2.66 intelcore2duo, 4gb memory and video card ati radeon Movility HD 4650 1GB of dedicated memory. Q apparently think they are good quality but hangs like when rendered by 20%.
    Any suggestions???
    Thanks.
