Activity › Forums › Apple Final Cut Pro Legacy › Problem Reading DVCPRO HD on a Mac
  • Problem Reading DVCPRO HD on a Mac
    Posted by Mark Denega on January 5, 2009 at 4:24 pm
    I have done a few days worth of research and cannot find a clear solution to this problem.
    I have a bunch of QT DVCPRO HD files that I am trying to edit with Final Cut 5.0.4. All of the footage was shot by a friend on Panasonic P2, imported to and exported from Final Cut Studio using the DVCPRO HD codec, put on to a disc and then uploaded to my external hard drive.
    I cannot play the files in QT or in Final Cut, even with my sequence settings on DVCPRO HD, 720p24. The audio plays, but there is just a black screen. No visual. Any ideas?
    I’ve read that Final Cut 5.0.4 was the first Final Cut compatible with DVCPRO HD, and that there were some bugs. Do I really need to upgrade to 6.0 to see this footage?
    Shane Ross replied 17 years, 8 months ago 2 Members · 3 Replies
  • Shane Ross
    January 5, 2009 at 7:43 pm
    No…as I stated on the Apple forum, all you need to do is reinstall FCP on top of what you have, and then update (if needed), to install the missing component.
    Shane
  • Mark Denega
    January 5, 2009 at 9:39 pm
    I’m confused. Wasn’t FCP 5.0.4 the first to be compatible with DVCPRO HD footage? If I can select it as a sequence setting, doesn’t that infer that I ‘have’ the codec?
    Just to be clear.
  • Shane Ross
    January 5, 2009 at 9:47 pm
    Not necessarily. You can have the preset and not the codec. Look in the HD>LIBRARY>Quicktime folder. See DVCPRO HD? If not, you are missing it.
    Shane
