Activity Forums Maxon Cinema 4D problem polyon with alpha channel enabled material reflects HDRI
  • problem polyon with alpha channel enabled material reflects HDRI
    Posted by Roy Mckenzie on April 27, 2012 at 3:18 am
    Greetings,
    I set up a polygon plane with an alpha material to crate some perforated metal. The holes the alpha channel creates in the plane reflect the HDRI I have on a sky object, it also does it with the HDRI on a sphere.
    I have a composting tag on the sky/sphere and checked off “not seen by camera”
    I have tried to trouble shoot it with limited success.
    -turned up/down ray depth and/or ray threshold
    -turned off transparency and/or “seen by rays” in composite tag of sky/sphere
    -excluded the plane in the composite tag of sky/sphere
    I have seen other people talking about this problem, but no acceptable solution. Has anyone figured out a good solution to this?
    Roy Mckenzie replied 14 years, 5 months ago 2 Members · 2 Replies
  • Siddharth Gautam singh
    April 27, 2012 at 7:15 am
    Hi Roy,
    I tried this out and turning off ‘Seen by transparency’ on the HRDI sphere seems to solve the problem.
    Siddharth G Singh
    Film | Motion | Illustration
    http://www.siddharthgsingh.com
  • Roy Mckenzie
    April 27, 2012 at 2:10 pm
    So it does! Thanks. It’s funny because I swear I tried that. Hmmm oh well thanks again.
    Thank you
    Roy
