Activity Forums VEGAS Pro problem plz
  • problem plz
    Posted by Arisfr Frans on August 8, 2012 at 9:45 pm
    i have vegas pro 11
    my camera is samsung wb150f it records in HD 1280×720 30fps
    plz tell me the best properties and rendering setings
    i have lag on video preview and lots of rendering problems
    thanks for the help :)))
    Arisfr Frans replied 14 years ago 2 Members · 2 Replies
  • Jeff Schroeder
    August 9, 2012 at 2:24 am
    Set your project properties to the frame size and rate of the video, in this case 1280 x 720 @ 30 fps. Or you can let Vegas make these settings by using the match media (or whatever it’s called) in the top right of the project properties window.
    Render using the Sony AVC template with the same numbers.
    If you are using a lot of filters turn off the filtered view using the split screen view (select all) in the preview window. Your filters will still be there when you render and the viewing will be less choppy. Otherwise you need a faster processor to handle the workload.
    Jeff
    2-Xeon X5680 @ 3.33, EVGA SR-2 Mobo, 48GB DDR3, GTX 580 3072MB, 16TB Attached Storage, Win7, Vegas 11 x64
  • Arisfr Frans
    August 9, 2012 at 10:32 am
    i realy try all of them stil having rendering problems
    im thinging about codecs waat codeks to download ?
