Activity Forums Apple Final Cut Pro Legacy Problem Playing back video footage from Cannon AVCHD camera
  • Problem Playing back video footage from Cannon AVCHD camera
    Posted by Paula Stein on November 30, 2010 at 6:40 pm
    I have transferred HD video footage from a Cannon HD camera HDD (AVCHD) through Log and Transfer in FCP 7. All went well, but every time I play in the time line, the footage stutters and doesn’t play properly.
    The sequence setting matches and no rendering.
    Anyone else have this problem, any solutions??
    Thank you in advance for your help!
    Paula
    “A journey of a thousand miles must begin with a single step.” ~Lao Tzu
    Paula Stein replied 15 years, 9 months ago 2 Members · 4 Replies
  • George Mandl
    November 30, 2010 at 6:57 pm
    Does the footage play smoothly when you load it into the Viewer window? Also, what are your system specs? RAM?
  • Paula Stein
    November 30, 2010 at 7:07 pm
    George, the footage does not play smoothly in the viewer either. Steps and stutters.
    my specs:
    Model Name: MacBook Pro
    Model Identifier: MacBookPro1,2
    Processor Name: Intel Core Duo
    Processor Speed: 2.16 GHz
    Number Of Processors: 1
    Total Number Of Cores: 2
    L2 Cache: 2 MB
    Memory: 2 GB
    Bus Speed: 667 MHz
    Boot ROM Version: MBP12.0061.B03
    SMC Version (system): 1.5f10
    Serial Number (system): W86184S8THY
    Hardware UUID: 00000000-0000-1000-8000-0016CB969AB9
    Sudden Motion Sensor:
    State: Enabled
  • George Mandl
    November 30, 2010 at 7:13 pm
    I’m going to guess its a RAM issue. Unfortunately this is not an easy or cheap upgrade for a MACBOOK PRO.
    It could also be a drive speed issue. Are you playing the footage off of an internal drive on the laptop? Or is your media on an external hard drive? If external, how is it connected to your laptop?
    One other question. Will it play in Quicktime smoothly?
  • Paula Stein
    December 1, 2010 at 9:47 pm
    The clips are on the macbook hard drive. The quicktime files when played also step frame and stutter. Thanks for your help.
